Order Ford 8N Parts Online
Lifting the 8N Hood
TJ
08-21-2002 09:08:10
Can anyone tell me the procedure for lifting the hood on my 8N.....like disconnect radiator,empty gas tank etc..... .?????
Mountainman
08-21-2002 12:46:25
 Re: Lifting the 8N Hood in reply to TJ, 08-21-2002 09:08:10
After you get the two lower bolts out spread the doglegs slightly and remove the grill rather than waiting for it to fall out on it's own.
Mountainman...CA
Jim (VT)
08-21-2002 09:18:14
Service manual covers this...you only have 6 bolts, 4 on the dash and two on the front at the bottom of the grill. You also need to disconnect the gas line from the carb. If you have a good bit of gas in the tank, you might want to empty it...makes it lighter to lift. I have taken mine off by myself, but I would recommend two people to lift it off..not heavy but cumbersom. You will also want to have a couple of sawhorses set up (close together) to rest the hood assembly on when you get it lifted off. Also make sure you pull down the wireing harness from the clips on the underside of the hood...
And... Evil Steve
08-21-2002 10:55:09
 Re: Re: Lifting the 8N Hood in reply to Jim (VT), 08-21-2002 09:18:14
... remove radiator cap. Sorry, had to add SOMETHING. LOL
Jim (VT)
08-21-2002 11:58:48
 Re: Re: Re: Lifting the 8N Hood in reply to And... Evil Steve, 08-21-2002 10:55:09
Yep...can't forget the radiator cap.
Oh yes you can... Evil Steve
08-21-2002 12:07:25
 Re: Re: Re: Re: Lifting the 8N Hood in reply to Jim (VT), 08-21-2002 11:58:48
... I did! It's the little things...
Jim (VT)
08-22-2002 05:36:39
 Re: Re: Re: Re: Re: Lifting the 8N Hood in reply to Oh yes you can... Evil Steve, 08-21-2002 12:07:25
Hey...we forgot to tell him about the Grill...but we did remember the radiator cap...
