Order Ford 8N Parts Online
8N-Dead in the morning?
John
06-28-2002 10:26:26
I have a Side dist. 8N that runs great, shows a charge when running, starts all day but when left overnight the battery goes down so far that it wont start in the morning. Has rebuilt gen, new wiring,new volt reg. Battery shows good when tested, I don't know what to check next. Thanks.
Terry Alexander
06-28-2002 11:26:56
 Re: 8N-Dead in the morning? in reply to John, 06-28-2002 10:26:26
John,
I fought that battle for a whole summer. Come to find out....it was an old worn out ignition switch.
HTH
Terry Alexander
Jack - Illinois
06-28-2002 10:59:35
Do Danny's trick and if no spark, leave the cable off all night. If it starts next morning then problem is not the battery. Next leave the hot wire off the regulator all night. Oh and if it don't start when you left the battery cable off it has to be a bad battery. I don't see how it could be the generator as it is the regulators job to disconnect it when the engine is shut off. Hope this helps
Danny in CO
06-28-2002 10:29:26
Sounds like you have a short somewhere. Take a battery cable off. With the switch off, quickly touch the cable back to the battery post. If you get a spark, you have a short.
Danny
