Order Ford 8N Parts Online
Is 8N second gear really weak?
Dave OH
06-25-2002 23:12:06
Is Second Gear on the 8N really a weak gear that fails often due to design? Or is it that Second Gear is used so often because it seems to give a perfect speed to run at and keep the 1500rpm PTO speed needed for most equipment, therefore it is the one that gets broken most often?
Thanks for any opinions!
Dave, OH lee@stratos.net
Dave, OH
06-26-2002 21:58:15
 Re: Is 8N second gear really weak? in reply to Dave OH, 06-25-2002 23:12:06
Thanks for all the comments. After reading about Second Gear numerous times on the Board I had to ask. The concenses seems to be that Second Gear is the most used gear in brush hogging. Which is one of the most used features of the 8N. So, it seems that the Second Gear may not be weak as suggested many times, but is instead the most used gear, thereby the one most replaced.
Maybe we put a myth to rest. Thanks again everybody!
No.............dave#1
06-27-2002 04:17:39
 Re: Re: Is 8N second gear really weak? in reply to Dave, OH, 06-26-2002 21:58:15
It breaks because it is weak, I found this in the archieves
later,dave
ZANE
06-26-2002 18:26:11
I have been fixing N tractors and others for over fourty years. I have fixed probably 40 four speed transmissions in Ford tractors. 39 had the second gear broken while bush hogging in second gear.
What do you think this should tell you ????? ????
Tyler (MD)
06-27-2002 02:44:12
 Re: Re: Is 8N second gear really weak? in reply to ZANE, 06-26-2002 18:26:11
Wonder how many of those didn't have ORC's?
Interesting!
Tyman
JD
06-26-2002 20:13:38
That tells me darn near everybody bush hogs in second gear. If everybody bush hogged in third gear you would have been changing 39 third gears.
Tells you something==bj/8n/mt
06-26-2002 04:51:28
Whether it is because it is weak by design or because it gets abused the most, it is worth noting that second gear is the only gear the after market parts suppliers have bothered to make replacements for.
Your mileage may vary
It depends.......dave#1
06-26-2002 04:35:19
It's my understanding that 2nd gear has a smaller/weaker bearing/shaft (or something) than the rest of the forward gears, this is not a problem inless your bush hog'n, if you hit a large rock/stump, the shock can and will transfer up the pto shaft breaking 2nd gear.
In other words "Don't hog in 2nd !!"
later,dave
Tyler (MD)
06-26-2002 15:52:24
 Re: Re: Is 8N second gear really weak? in reply to It depends.......dave#1, 06-26-2002 04:35:19
Correct. Wouldn't a ORC help with the shock after running into that baseball glove/stump?
Tyman
Dave Smith
06-26-2002 18:08:53
 Re: Re: Re: Is 8N second gear really weak? in reply to Tyler (MD), 06-26-2002 15:52:24
Tyler, My Bush hog has a stump jumper. Do I need a base ball glove jumper to? Or will the stump jumper handle it?
If you want a real fun time , find some fence wire with the bush hog. Or a slinky. Need a pair of Sweed side cutters to handle that.
Dave <*)))><
Big Mike
06-26-2002 03:43:10
Tyman is spot on....just use common sense and an ORC when mowing and things will be ok..If not parts are available to fix it..... ...Big Mike
Tyler (MD)
06-26-2002 03:00:01
I believe it's been determined that 2nd gear is the one that's used more often than the others. I'd use it and not worry about it. Just use common sense and treat your tractor with care and you'll be fine.
JMHO,
Tyman
jeff m la..
06-26-2002 07:13:18
 Re: Re: Is 8N second gear really weak? in reply to Tyler (MD), 06-26-2002 03:00:01
when I brought my 8-N,was told second gear
had been changed,the old man ran the bush
hog in the ground and it broke..jeff m
