Limiter chains vs skid shoes for back blade
Mike G (Va)
11-19-2000 04:45:15
Hey Folks
I know that skid shoes were discussed recently, but I was going to use the limiter chains that I have. Should I deep-six that idea and go with skid shoes? My driveway has gravel layed in track so that I have a center hump.
brs
Mike G - 8N300465
45 2N (TX)
11-20-2000 08:21:03
 Re: Limiter chains vs skid shoes for back blade in reply to Mike G (Va), 11-19-2000 04:45:15
What are skid shoes?
Ron from IL
11-19-2000 09:57:28
Mike,
Limiter chains would not allow the blade to 'float' when needed--over bumps and dips, backing up, etc. I put a set of shoes on last year, and have not been sorry.
Ron
MikeC
11-19-2000 05:19:40
Hmmm...I think that either way may have an advantage/disadvantage depending on your circumstances. The limiter chains would do the job just fine, unless you have a drive with a hill in it. I have a steep drive, and I think with limiter chains the blade would be allowed to dig in when the front of the tractor leveled out at the road and the blade was still on the slope. Vice versa, if the front of the tractor started down the slope from a level area, the blade would lift up because of the limiter chains. But, if you have a level driveway, I think that limiter chains would also work just fine. I wonder what some of the experts on this most excellent board will say...
MikeC
11-19-2000 05:22:46
 Re: Re: Limiter chains vs skid shoes for back blade in reply to MikeC, 11-19-2000 05:19:40
PS-What is it that makes us nuts enough to be on this board between 4 and 5 am talking about skid shoes and limiter chains? :->
Mike G (Va)
11-19-2000 06:13:53
 Re: Re: Re: Limiter chains vs skid shoes for back blade in reply to MikeC, 11-19-2000 05:22:46
I'm at work. Had to work 12 hours on Sat. and now another 12 hours today. At least it pays for my N and other toys.
brs
Mike G - 8N300465
