Order Ford 8N Parts Online
8N HITCH
DICK JOHNSON
04-22-2002 10:38:14
GETTING READY TO HITCH MOUNTED DIGGER TO MY 8N. WHAT DO YOU USE FOR THE CENTER LINK? IS IT THE DRAW BAR SUPPORTS OR IS THERE A SPECIAL LINK?
ANK YOU
Dave, Sherburne, NY
04-22-2002 19:49:48
 Re: 8N HITCH in reply to DICK JOHNSON, 04-22-2002 10:38:14
There is a special piece called a top link in this area maybe a third arm where you are or something else . about 30 inches long swivels on both ends just like the ends of the lift arms but smaller holes. newer ones have threads on both ends to adjust the length . origonal Ford was two pieces of steel, slotted bolt holes for length adjustment
DICK JOHNSON
04-22-2002 12:55:37
IM AM SORRY I SHOULD OF SAID FIELD CULTIVATOR NOIT A DIGGER AS THEY ARE CALLED IN THIS AREA.
Dell (WA)
04-22-2002 21:13:27
 Re: Re: 8N HITCH in reply to DICK JOHNSON, 04-22-2002 12:55:37
Dick..... ...Yes there is an Cat-1 adjustable topling that should go between the trackor under the seat toplink to the field cultivator toplink. Generally adjust for level unless you need it to dig in more..... ....Dell
Dell (WA)
04-22-2002 10:46:34
Dick..... ..generally for 3-point post hole digger, its hitch and go. BUT WATCH OUT your PTO shaft might be too long. Their made to be cut shorter (both'em) Be certain that you have spare sheerbolts..... ....Dell
