Limiter Chains' Last Ride
Digger
04-06-2000 19:04:29
My limiter chains performed their final duty today. The right side chain held the lower arm while I removed the pin so I could install my spankin' new ZANE THANG. 5 minutes later I fired up the the old 9 for a test hop - the THANG worked as advertised without any adjustments. Thanks ZANE. I'm surpised that the limiter chain union isn't picketing your shop. You're putting the poor slobs out of business.
I'm cogitating on making an upper stop like the lower one (the mower's driveshaft will hit the deck if it's raised it too high). Any reason why an upper stop wouldn't work just like the lower one?
Digger
