Loader stopped working
coach a
11-14-2023 21:33:57
Had the 8N out and was clearing wood. Loader stopped working. Would go down, then even trying to go up lowered the bucket. Also a very. loud clicking or clacking noise coming from front pto shaft area. Could I just be low on fluid? Is there a zirk that needs greased? I took a video with my phone but NO CLUE about how to post it on here. Thanks in advance.
TheOldHokie
11-21-2023 06:01:35
 Re: Loader stopped working in reply to coach a, 11-14-2023 21:33:57
This ain't rocket science.
With the engine stopped disconnect the pump supply hose from the loader valve and stick the end of the hose in the oil filler on the loader. Start the tractor and verify the pump is spewing oil out the end of that hose.
TOH
Jim.ME
11-21-2023 04:53:39
Great the shaft from the motor is spinning, have you confirmed the pump shaft itself is spinning?
coach a
11-20-2023 16:49:28
Thanks. The shaft does spin. It looks no slower than it did before. Not sure what might cause the noise, considering the shaft is spinning like crazy, just zero pressure being built up.
old
11-15-2023 08:16:31
Most likely the drive hub and spline shaft have stripped out and need replaced
Ultradog MN
11-15-2023 00:52:16
Most of those loaders are powered by a hydraulic pump that is run off the front of the engine. Usually there is a shaft with a coupler between the front pulley and the pump.
The loud clicking/clacking noise you hear is likely the shaft or coupler that has failed.
Start the engine and look to see if the pump is actually spinning. If it is not you know where to look.
