Mad Farmer
- Location
- Northeast
1940 9N
It seems the bushing is wearing/worn out on the clutch pedal.
It's got to the point where the clutch pedal contacts the brake paul arm (parking brake) and the clutch pedal is hard to depress far enough to disengage the clutch. I adjusted the clutch linkage and that helped for a while. But now the clutch pedal pushes down the paul arm until the brakes begin to engage.
It seems it will be a PITA to replace the bushing on the shaft. What is involved to get the shaft out? Are bushings available? Do I have to get into the brake assy?
My other idea is to loosen the bolt on the paul arm, and rotate the paul arm a bit on the shaft. Not sure how easy that would be seeing they have been partners for 80 years. Maybe penetrating oil first, then heating with a torch.
I rarely use the parking brake but think it would still work with the paul arm rotated a bit.
Thoughts and/or suggestions on this?
This post was edited by Mad Farmer on 02/09/2022 at 01:11 pm.
