Hello,
My lift arms slowly lift up and stutter on the way. I have had the cover off and made all the adjustments I could find. Still does the same thing. With the side cover off I can push the arm towards the pump moving the pump plunger forward and the lift arms shoot up like they should.
I cannot figure out how to adjust the lift control arm any further so the arm moves that far when the lift lever handle is pulled up like I can do when I reach in the side cover and manually move the lever.
It's like there is some kind of slack in the lift control lever I can't get rid of.
I've already rebuilt the pump, new fluid, and adjust the arms using Zanes adjustment tool.
I'd appreciate any input.
