Company Logo (800) 853-2651 Shop Now
Order Ford 8N Parts Online
Ford 8n over/under aux trans won't shift
Little Fred
05-25-2023 21:10:38
it works fine in whatever gear its in.... but if I try to put it in another range it doesn't work..... also if I go down a hill with a heavy load (two unloaded hay wagons) it will pop out of range (not fun) can I fix whatever's wrong with it without splitting the tractor again? someone said the detents might just be worn out.....
thanks!
Bruce(OR)
05-25-2023 22:48:04
 Re: Ford 8n over/under aux trans won't shift in reply to Little Fred, 05-25-2023 21:10:38
Sherman, Hupp, F&T ?
Which one is in there?
If the detents are worn/sticking, You get to pull it apart to fix it. Just be sure to prefill prior to install.
Little Fred
05-26-2023 03:37:58
 Re: Ford 8n over/under aux trans won't shift in reply to Bruce(OR), 05-25-2023 22:48:04
Sherman
Bruce(OR)
05-27-2023 12:38:29
 Re: Ford 8n over/under aux trans won't shift in reply to Little Fred, 05-26-2023 03:37:58
You already have your answer. Now that your working on an N Tractor, it can be said, NJoy!
