Nyquil Junkie
I'm rigging up a counterweight on the 3 point and it suddenly occurred to me that I'm not real sure how to properly do it.
First up is this top link connector, it has 3 holes. Before I break something, which hole is for what? I'm hooking up a counterweight that is going to be set and chained up at a good height. So which hole should a hook the toplink to?
Speaking of chains... I assumed those 2 hooks on the side of the rearend were to hook the limiter chains to and the other end of the chains hooking to the end of the lift arms at the pins. I actually have no idea id that is correct or what those hooks are suppose to be used for.
Help me out here w some info and maybe some pics how you guys do it.
Thanks.
Thanks.
