Friend's 9n (not sure year) sat for a long time in a barn. Did a coolant drain/refill, oil, got it to start and run. Took a short spin around the yard, let it sit to just run some, and it did. Cold here in MI, at some point wondered about the coolant. Took off the rad cap, saw no water movement. We do notice oil in the water, not huge amounts, but not 2 drops...few days later, redrained, took off the lower coolant tube and when turning the fan, can see the shaft moving, but can't see the water pump vanes. Not sure if it's turning or not.
With the thermostat(didn't check that yet), it's possible that water doesn't move until the thermo opens correct? We should probably retry and let it sit and continuously watch it and it should open at some point I suppose. Or I could take the thermo out and pan test it?
