If it is for an IH or other carb, it won't work on a FORD. You can start by measuring the two-bolt hole spread pattern on the carb flange mounting surface. Carbs were
designed for a specific engine size. The N-Series used a 119 CID block. When the NAA/Jubilee model came out it now had a 134 CID block and then in '54 the 172 CID
block so they all had different carbs too. FORD used Marvel-Schebler as their carburetor suppliers starting with the 9N tractor model. Their model numbers were ID'd
with the TSX prefix code. M/S supplied carbs to any others tractor makes like IH and JD. The '11' you see means nothing - it is simply a manufacturers code of some
sort. M/S cast recessed the TSX model into the bottom half of unit on a 'ping-pong paddle' type of cast boss at first, then went to a brass ID tag riveted on around
1948. The ID tag had the TSX unit model number and a date code stamp to designate the date the unit was manufactured. Models were different for different tractors and
some parts kits contain a lot of the same parts. But, just because they look the same, doesn't mean they are. Details like the hole spread for the mounting flange
matters, the Venturi size, and the float size. The The M/S carbs used on FORDS are listed in my list below. I have a Marvel-Schebler manual with all the FORD models
but no other make so I can't compare the specific part numbers to others used by the different tractor makes. If you want a copy, email me, Ithink I have my email
working now.
MARVEL-SCHEBLER TSX-38 CARB, w/CAST RECESSED BOSS ID TAG:
MARVEL-SCHEBLER TSX-33 CARB, w/CAST RECESSED BOSS ID TAG:
*NOTE: CAST RECESSED 'PING-PONG PADDLE' BOSS ID TAG
MARVEL-SCHEBLER TSX-241B CARB, USED ON FORD 9N-8N MODELS:
NOTE: BRASS RIVETED DATE CODE ID TAG, USED FROM 1948 ON. '4-51' DESIGNATES UNIT BUILT IN APRIL 1951.
NOTE: Always measure the carb intake flange bolt hole pattern pattern for fit if unit is unknown:
FORD TRACTOR M/S CARB TSX MODELS, N-SERIES THRU HUNDRED SERIES:
TSX-33, 9N, 2N - EARLY 8N
TSX-38, 9N - INDUSTRIAL (also on warhorse model) only, to 1943
TSX-241, 241B, 241C - 8N
TSX-428, EAE9510C, B2NN9510A, NAA
TSX-580, EAE9510D, B4NN9510A, 600/700
TSX-593, EAF9510D, 800/900
TSX-706, EAF9510G, B6NN9510A, 800/900
TSX-692, 310746, 601/701
TSX-771, 312778, 801/901
TSX-662, 310015, 801/901
TSX-769, 312955, 801/901
TSX-765, 312954, B8NN9510A, 601/701
TSX-813, C0NN9510C, C0NN9510G, 801/901/4000
MARVEL-SCHEBLER/BORG-WARNER TSX CARB MANUAL, FORD MODELS ONLY:
Tim Daley(MI)
