Company Logo (800) 853-2651 Shop Now
Order Ford 8N Parts Online
8n hydraulics
Gary Singleton
01-31-2023 07:28:23
the top piston was redone lift works good when pump is running but when I slow the engine down the lift goes down slowly rev engine up lift goes back up where should I check seems like a valve is leaking down or could it be the piston any help would be apperciated
Abbby
02-01-2023 04:23:19
 Re: 8n hydraulics in reply to Gary Singleton, 01-31-2023 07:28:23
TheOldHokie is correct
TheOldHokie
01-31-2023 15:15:11
Quote: CVPost-Leroy (quoted from post at 12:51:45 01/31/23) What you are describing is normal for a new tractor direct from the factory. The Lift piston cannot seal tight enough to keep oil from leaking past. The tractors I have had all do that, 41 9N, 44 @N bought new, NAA, Ferguson TO-30. even the 65 and 68 Ford 4000 and 68 5000
Leaking down so fast position control on an 8N can't correct is not normal and indicates a very large leak somewhere.
TOH
This post was edited by TheOldHokie on 01/31/2023 at 03:16 pm.
Leroy
02-01-2023 09:47:31
 Re: 8n hydraulics in reply to TheOldHokie, 01-31-2023 15:15:11
I did not say anything about full throttle but just a bit. So explaine to me how the 8N was so different in not needing anything above an idle when the 9N, 2N, NAA, TO039 , 65 4000, 68 4000 and 68 5000 all did reqyire a bit of throttle. And I have had all these tractors and still have the 9N and the 2N bought new in may of 44. So what is so much different in the 8N that it can do at idle what none of the others could do. I am talking about a 50-75 RPM difference.
Leroy
02-01-2023 08:20:11
I don't see anything about leaking down so fast. New piston and rings might or might not help.
Leroy
01-31-2023 08:51:45
JMOR
01-31-2023 07:52:49
Quoting Removed, click Modern View to seeYou have to eliminate all nine potential leak points, by inspection, etc.
Third Party Image
