generator mount 52 8N
trying to put the gen on my 52 8n. it has the left side gen. if I put the strap mount on with the engine side ears in front of the tractor mount the gen is too far forward, pulley does not line up. if I put I put the ears too the rear the adjuster hits the block, but the pulleys line up. I can't describe it any better. it must have worked before I took it all apart for painting.
This help?
(quoted from post at 11:45:21 09/21/22) Did you put the pully on backwards?
Common problem with the late 8N generators, even for rebuild shops.
When it's on correct it [b:b669a34dd6][i:b669a34dd6][u:b669a34dd6]"looks"[/u:b669a34dd6][/i:b669a34dd6][/b:b669a34dd6] kinda backwards
Following pics are correct orientation
This post was edited by jimtrs on 09/21/2022 at 10:11 am.
(quoted from post at 13:04:50 09/21/22)
When it's on correct it [b:6ec9559d97][i:6ec9559d97][u:6ec9559d97]"looks"[/u:6ec9559d97][/i:6ec9559d97][/b:6ec9559d97] kinda backwards
hanks, the pulley was on backwards. it must have been that way when I took it apart because I never took the pulley off. THANKS AGAIN
