Dozer Blade Manual
Ishmeal
I pick up a partially complete dover blade this weekend. It consists of the blade, the tubular frame, cables & rollers, pins and the rod that goes over the lift arms. I may have a set of the brackets that go on the tractor. I believe the rear section of the of the frame that goes under the lift arms is missing, if it mounts that way. I am not familiar with this set up. Thank you in advance.
Adam.
Due to a long standing feud between this
site and the site below we can not post a
link to anything there.
Type this link into your browser and it
will get you there.
There are several manuals for the Dearborn
dozer blade, snow plow and the universal
frame there.
Have a look around. You may find what you
need.
(quoted from post at 10:25:51 09/13/22) Due to a long standing feud between this
will get you there.
frame there.
need.
<img src=https://www.yesterdaystractors.com/cvphotos/cvphoto135557.png>
I found the site and the info, thank you....
That Other Site is all but done now anyway -the admins want to go to Fakebook. I have most all of the OEM DEARBORN Manuals anyway, many were posted there by myself. There were a few different DOZER BLADES so I can send you the Master Parts Catalog that covers all of them. You're aware that DEARBORN/FORD are long out of business and parts are no longer available, right? Might find some hydraulic hoses, bearings, and bushings that are comparable to OEM ones - MPC has sizes for most. Meanwhile, see if any of this helps you. My email is also open...
DEARBORN ANGLE DOZER BROCHURES & FRAME MPC:
<img s rc=http://i15.photobucket.com/albums/a379/ploughNman/ANGDZBR1.jpg>​
Tim Daley(MI)
