1952 8n tractor
Ken West
New User
I am at a loss as to what the differential mounted drawbar with the 1" hole and the bottom hole has a spring in it is used for on the tractor i recently aquired is for? No one in my tractor club or area seems to know. Thank for any help. Ken W
It is used to attach the uncommon OEM swinging drawbar with roller.
A much more useful solution is a modern swinging drawbar kit available from various suppliers.
(quoted from post at 13:54:26 08/28/22) I am at a loss as to what the differential mounted drawbar with the 1" hole and the bottom hole has a spring in it is used for on the tractor i recently aquired is for? No one in my tractor club or area seems to know. Thank for any help. Ken W
Its for use with an under axle drawbar. The original 8N system looked like the top picture. The newer aftermarket version shown in the second picture replaces the OEM bracket and is a lot better.
TOH
(quoted from post at 15:09:14 09/01/22)
If you don't have the draw bar, here is another use for the bracket.
Really? A hook? Just don't get stuck and you wont have to pull that N out!
Rick
