Hydraulic Lift on 1944 2N
N2N
New User
When I raise lift arms on my 44 2N with any implement, they will raise slowly at first as one would expect, but if I go very far up with the lift lever, it will suddenly raise completely up too soon, too quickly and too far. When in raised position will also leak down gradually. Any suggestions certainly are much appreciated.
(quoted from post at 20:06:34 08/29/22) When I raise lift arms on my 44 2N with any implement, they will raise slowly at first as one would expect, but if I go very far up with the lift lever, it will suddenly raise completely up too soon, too quickly and too far. When in raised position will also leak down gradually. Any suggestions certainly are much appreciated.
That lack of control is the nature of a 2N. Gradual leakdown is normal but rapid leakdown usually indicates bad piston seal in the lift cylinder.
TOH
