teachingscience
Hello, I need some help form all you 8N experts before I tear into my tractor. Recently bought this 8N and the lift is acting up. WIth no load it lifts as normal
but when you put weight on it, it pulsates and lifts really slow. I already replaced the piston and seal in the lift cylinder. That helped, it wouldn't lift under
load at all with the old one. To me, it feels like only one or two of the pistons in the pump aren't pumping under load. Assuming I'll have to pull the pump but
what problem should I look for?
Thanks for all you advice
Charlie
Charlie
