Good day all!
First post, here we go! For the abbreviated version scroll down to : ******START HERE
1950 8N. We got it started on Saturday for the 1st time in YEARS! I noticed no oil pressure even on a new gauge. I had already removed and cleaned the oil filter canister., along with the lines. It had about a 1/2 inch of sludge in the bottom so I assumed the oil pan would look similar at least. I replaced the cleaned canister with a new filter, tightened the lines and put about a third of a quart in with the new filter.
Back to the first start: Ran long enough to determine no Oil pressure, but idled on its own. Drained oil from crankcase and let it drip all night. It was pretty bad looking stuff with the back of the cap being full of sludge! When I look up into the pan, am I looking at the oil pickup? It was clean, good sign I think.
Today: Fresh oil, checked my lines to make sure I had not forgotten one, all good. Crank and start: No oil pressure. Engine sounds a lot better with fresh oil, just not seeing oil pressure. I cracked a couple of the fittings and saw oil on each side of the canister. On my engine, there is a brass T behind the exhaust manifold that splits off to the gauge. After a minute of running it had no oil. I left it off, restarted and suddenly had oil there.
******START HERE Now: 3pm Central time. I start engine and as oil pressure builds, my oil filter canister begins to hemorrhage oil! I have a new seal on the top. I even put a second seal on it and made sure the bolt was tight.
Where do I start? What is the oil circulation/route? As in high pressure/low pressure sides.
What does the governor do as far as motor oil?
John B.
Nashville, TN
1950 8N
John B.
Nashville, TN
1950 8N
