Bolts for Headlight Bracket?
RTR
Trying to figure out what this bolt and washer is for on the headlight bracket? I see the little trim "wings" offered aftermarket and some distributors include those bolts. I just thought the headlights held them on when pulled tight to the hood.
I'm doing as much research as I can before I am ready to reassemble so I have [i:6162ac6016]most [/i:6162ac6016]all parts ready to go.
(quoted from post at 10:52:15 08/24/22) Trying to figure out what this bolt and washer is for on the headlight bracket? I see the little trim "wings" offered aftermarket and some distributors include those bolts. I just thought the headlights held them on when pulled tight to the hood. That bolt holds the wing and reinforcement to the side panel to keep it from swiveling on the headlight mount bolt. Screws into the wing from the inside.
I'm doing as much research as I can before I am ready to reassemble so I have [i:83c6faf1c1]most [/i:83c6faf1c1]all parts ready to go.
(quoted from post at 21:31:03 08/24/22) That bolt holds the wing and reinforcement to the side panel to keep it from swiveling on the headlight mount bolt. Screws into the wing from inside.
Thank you Tom. I looked at my original doglegs and they only have one hole in them I m assuming for the headlight. This is a 1950 model 8n. Not sure where that bolt would go!
I don't know what you mean about ...little trim 'wings' aftermarket and some distributors include those bolts but wherever you got this info it is wrong. Part
Number 2N-13022 Headlight Mounting Bolt was/is only used for mounting the headlights to the doglegs. The hollow bolt was never used on anything else including the
distributor. More bad/wrong info given somewhere but not from me; I only post the data facts. FORD TRACTOR Lighting Kits were never a factory feature from the Rouge
Plant or later Highland Park Plant until the 800 Model and then only headlights were standard. Lighting Kits were only a dealer optional accessory til 1954. The
headlight mount was to be on the doglegs with two punch-outs for them using the two original Winged Medallions, from 1939 until April, 1950. The wings had two holes,
one for mounting and one to mount the headlight on with. The wings were fastened onto the dogleg with a 5/16-24 x 3/8 hex bolt from behind the sheet metal with the
reinforcement bracket, p/n 9N-13102, and the 2N-13022 Special Hollow Bolt that fed the light wire thru and fastened with -20 Hex Nut and Lockwasher. In April 1950, as
a cost savings move, FORD obsoleted the winged medallion style and revamped the lighting mounts to a simpler round cup style, p/n 8N-13472, and now used a smaller,
square, one hole reinforcement bracket, p/n 8N-13102. The round cup was used on both the Left and the Right sides so no longer a need to have a dedicated LH and RH
part. The round cups were used up until the Thousand Series models in 1962. Note, too, that the doglegs also were revamped in 1950 and now only had one punch-out for
headlights. Early 9N doglegs had no punchouts. Many N-Owners never had headlights installed thus their doglegs may still sport the punchouts intact. I have all the
original lighting kit drawings, instructions, and spec sheets that came with the kits and nowhere else. If you would like a copy, my email is open. Also, FWIW,
lighting kits used the TAURUS Taillight from 1939 thru 1949. The taillight was then obsolete and FORD went to the DUOLAMP style taillight. I have a NOS/OEM TAURUS
taillight for sake if interested see PIX. I also have a NOS set of mint, NIB, OEM Tract-O-Lite headlights including the original Dearborn Motors part box from the
dealer. Dennis Carpenter makes all the lighting parts see LINK.
FORD TRACTOR LIGHTING KIT, AFTER 1949:
FORD N-SERIES TRACTOR TAURUS TAILLIGHT, USED 1939-1949:
Tim Daley(MI)
HEADLIGHT MOUNTING BOLT 2N 13022
(quoted from post at 21:20:09 08/24/22)
he 1950 and newer 8N only had a type of cup washer to mount the light not the wing style so it only would have 1 hole. You could drill the second hole to use the wing. I think they do look better.
