DMartin9N-2N
Good morning: My 9N's starter switch has been working fine for years. Yesterday, it did not work when I first tried to start engine. I wiggled the gear shift lever, to make sure the interlock feature was not blocking the starter button/pushrod system. After pressing the button several times, the switch worked, engine started. I am thinking I need to check whether the switch is loose where it mounts (below the battery, if I recall correctly). What problems has anyone had with a working starter switch failing? Any personal experiences with this would be helpful.
Dennis M. in W. Tenn.
