Roger in Iowa
Pictures of Shaun's wedges installed under the axle center to stabilize the engine from falling to the side when splitting the tractor.
Other pictures are bolts and wire to keep the front spindles from turning when the tractor is split. Bolts keep steering arm from turning to the rear, and wire keeps the arm from turning to the front.
