newbie with a new (to me) tractor
Bigtoe71
New User
Hi,
I'm new to tractors as I inherited my uncles 52 with a FRONT mount distributor. It's still 6v and I'm keen to keep it that way. It doesn't really run in cold weather and I'm not using it for anything but some work on the ground, and not at night requiring lots of light etc.
It had been running but it would loose power and die. After taking off the cowl I determined that the original looking harness needed replacement. Re-did the wiring harness. The person that had been previously been working on it said it needed a new voltage regulator, and one was on hand so I replaced that as well. I am pretty certain that it went in as planned for the harness and regulator.
I also replaced the spark plug wire with a copper lined set. The spark plugs are new. The aftermarket starting button would continuously run so I repaired/replaced the original starter near the shifter, and got rid of the aftermarket. I couldn't remember or recall if the coil was new or not, so it has a new coil and I also replaced the distributor base and cap (brass pins inside on the on on the tractor were worn flat to the bakelite). Still cannot get any spark out of the system.
I was looking over other posts and got the 75 tips article, and have notes on several points. the wiring diagram fits what I matched on the available images.
I cannot recall if the generator on this one is adjustable or not, so any input on that would be great. ANY input or tips would be helpful. The tough part for me is the long drive to get to the tractor, and there are no tractor supply places near the location in NW WI.
Thanks in advance.
First, thank you for all the info in your post. It makes diagnosing your problem a lot easier.
Nope, a 1952 would be a side distributor. If it indeed is a FRONT distributor, with the coil mounted on top of it. Is it?
Still cannot get any spark out of the system. (brass pins inside on the on on the tractor were worn flat to the bakelite).
Your bushings are shot. The shaft is wobbling all over the place & the rotor ate the pins in the cap. Remove the distributor ( you need to do that anyway to replace the points if it is a frontmount) Replace the bushings, replace the points and set the timing.
I cannot recall if the generator on this one is adjustable or not, so any input on that would be great. Doesnt matter because that has nothing to do with no spark.
75 Tips
If it is a 1952 it will have 4 speed transmission. That said if it is front mount distributor the engine is from an earlier 9N/2N/8N; a "frankentractor". Check the serial # on the engine.
What Bruce said about the distributor bushings being shot.
Clean up real good all around the front of the engine and pull the distributor. When you replace the bushings make sure the advance mechanism also is working. Read up on how to do this and only buy quality parts for replacements. Where did you buy the coil from? I know the ones from TSC have serious quality control problems. The old coil might still be functional?
Timing the front mount is like nothing you've seen before, make that part of your schooling.
This is the best link I've found with step by step instructions/pictures to R + R front mount distributors:
http://www.myfordtractors.com/distrbldfrnt.shtml
The 3-brush adjustable generators are single wire and have a screw on the rear to adjust the third brush for output. It will have a round cutout rather than a square voltage regulator connected to it.
Post some pictures so the guys here can help you out better.
And welcome to being an N owner.
Front mount distributor cap looks like <a href=https://www.yesterdaystractors.com/Ford-8N_Distributor-Cap_9N12106C.html>this</a>, and side mount distributor cap looks like <a href=https://www.yesterdaystractors.com/Ford-8N_Distributor-Cap-Clip-Held_NCA12106A.html>this</a>. Side mount distributor has a clip to hold the rotor in place. If the clip is missing the rotor can wobble all over the place. Clip is <a href=https://www.yesterdaystractors.com/Ford-8N_Distributor-Rotor-Clip_8N12213.html>here</a>.
Per the serial number on the block, it's a 52, which is what's confusing me. I may have some sort of frankenstein on my hands....the vin is 8n49***
I know this is gonna be a learning curve.
and I appreciate the help. I responded to
Bruce but got anyone else, the Vin is
8n49###, which matches the 52 purification
year but....
I have included some pictures
(quoted from post at 10:28:33 08/15/22)
(reply to post at 07:03:16 08/15/22)
I think what Mad Farmer meant to say is, If it's an 8N it will have a 4 speed transmission.
That's what I implied with the 4 speed comment, should have been more clear, 4 speed = 48-52. But a 52 should be side mount engine.
pics
Not a 52. SN 8N49*** (5 digits). early steering gearbox (4 bolt sector) make it a 48. 52 serial number would have six digits and would have later steering gearbox (2 bolt sector) and exclusive to 52 a screw halfway between dash and steering wheel on front side of column for adding oil.
The first thing you need to check is for battery voltage at the coil. Yes, you need a meter for that, not a light. With the key on, you should see battery voltage ( 6.35 v) with the points open and about half that with the points closed. If you do not see either, the problem is between the battery and the coil, e.g., the resistor, ignition switch or a bad connection.
Assuming that the bushings & advance weights are ok (*see below), & that you have correct voltage to the coil , the most common reasons for no spark or a weak spark on the front distributor are below. Check each one carefully. Even if you find a problem, check all 10:
1. The insulator under the brass concave head screw & where the copper strip attaches. (it's fiber & will wear out; poke & prod w/ your meter leads to make sure it still works) If you need to replace the insulator, use a .250 x 3/8 nylon square nylon anchor nut available at most big box home stores.
2. The pigtail at the bottom of the coil not making contact w/ the concave head brass screw inside the distributor. (With the coil on, the pigtail must firmly contact the brass screw. No contact = no spark) Check for continuity between the top of the coil and the pig tail; a 6 volt coil will be around 1 ohm & a 12 volt coil should be 2 to 3 ohms.
3. The copper strip is broken or grounded to the plate. (look very carefully for cracks & breaks) .
4. The distributor is not grounded to the block because of paint or grease acting as an insulator. Or the points plate is covered in oil.
5. The tab on the bottom of the coil not making contact w/ the brass button on the cap. (With the cap on, the tab must firmly contact the brass button. No contact = no spark.) Check for continuity between the top of the coil and the tab; you should see about 6k ohms.
6. A grounding issue inside the distributor: Incorrect positioning of the spring clip on the plate causing the pigtail to ground. (the open part of the clip goes between 7 & 9 o'clock on the plate. That puts the straight part of the clip opposite of the timing screw at 3 o'clock) or the condenser wire is grounding to the plate or side of the distributor.
7. Incorrect seating of the coil on the distributor due to a loose bail or no gasket.(the coil must not move at all; if it does, replace the gasket or bail. Or stick some cardboard under the bail).
8. Water/moisture inside the cap due to gasket failure or the absence of a gasket. (the cap AND coil have gaskets)
9. Dirty/corroded/burned/incorrectly gapped or misaligned points. I use only Wells, Blue Streak or Echlin brand points (* *see below). If you are using quality points and cannot get the gap to open to .015, chances are you need to replace the bushings. If the shaft has any sideways movement AT ALL, the bushings must be replaced. (*** see below) If the tractor has been sitting unused for a few months, its highly likely that the points are glazed. Dress them with brown paper or card stock. Do NOT use a file or sandpaper. That removes the thin metallic coating on the surface and reduces point life considerably. With the points closed, you should have continuity between them; high resistance means they are glazed.
10. Burned rotor, cracked/carbon tracked cap. Brass dust in the cap is a sure sign of bushing wear.
After find the problem & re-check the point gap, do a continuity check before you put the distributor back on the tractor. Before you start, make sure your meter/light works.
With the distributor still off the tractor, follow these steps:
1. Coil off, cap off, points open. One probe on the brass screw & the other on both sides of the open points. On the side closest to the cam, you should have continuity. Not on the other side! If you do, you will also have continuity everywhere because the points are grounded.
2. Coil off, cap off, points open. One probe on the brass screw & the other anywhere on the body of the distributor. You should have no continuity! Now, rotate the tang on the distributor....as the points open & close, you have continuity (closed) and lose it when they open.
3. Put the coil on the distributor, cap off, points open. One probe on the lead on the top of the coil, the other on the cam side of the open points. You should have continuity!
4. Coil on, cap off, points open. One probe on the lead on the top of the coil, the other anywhere on the body of the distributor. You should have no continuity!
At this point, I just put the distributor, coil & cap all back on the tractor as a unit. The reason I do this is because it is real easy to get the cap or coil misaligned trying to put it back together, one piece at a time. The result is something gets broken or you get a 'no spark' problem.
It's possible to put it back on wrong & break it. Look at the slot on the end of the cam shaft. Whatever angle it happens to be, turn the distributor tang to match it. Make sure you can tell the wide side from the narrow side on both the cam & distributor! (close counts). Place the distributor on the front of the engine, gently push it in place & slowly turn the distributor body until you feel the tang slip into the slot. Rotate the distributor body until the bolt holes line up. Hand tighten the two bolts until the distributor body is flush with the timing gear cover.
* Unscrew the plate hold down screw & remove the C clip to get the plate out. Remove the shaft & weights. The weights should freely move. The tracks should not be wallowed out.
** NAPA part numbers:
. Points: FD-6769X or ECH CS35
. Condenser: FD-71 or ECH FA200
. Rotor: FD-104 or ECH FA 300
. Cap: FD-126 or ECH FA 350
** nnalert's kit:
Heavy-Duty Point Set, Condenser, Heavy-Duty Rotor, Heat Range Matched Spark Plugs. Packed 6 to Master Carton. Contains: 1-9N12107 Point Set, 1-AONN12300A Condenser, 1-9N12200 Rotor,1-9N12104 Gasket Kit,4-AL437 Spark
Plug,1-015 Gauge, 1-025 Gauge.
** Distributor cam lube NAPA:
https://www.napaonline.com/en/p/ECHML1
*** There are three ways to replace the bushings in a front distributor:
1. Buy new bushings (part numbers 9N12120 front & 18-12132 rear). Press out the old ones, press in the new ones and ream to fit. CAUTION: do not try this unless you have a press & know how to use it. If you break the base, a new one costs $130. If you bend the tower which holds the front bushing, a new plate will cost you $30. Resist the temptation to buy a new plate; most are pot metal and the threads will wallow out about the third time you change the points.
2. Take the new bushings and distributor to your local machine shop.
3. Send the distributor out for bushing replacement if you do not have a local machine shop
75 Tips
