woodman1928
Do when i was restoring my battery tray i welded up the two homes for the battery hold downs someone jn the past had mounted the ground cable to one and had a wire clamp bolted to the otherand in my mind i thought that the PO had drilled them along with the 4 other 1/4" holes that were drilled along the sides. Well when i mounted and dry fit the battery tray it hit me that welded up those holes and now have no idea were they are supposed to be.
Can some one take a picture with a tape measure on theirs from the front coner to hole center so i can re drill mine.
Also ehat soze hole were they 5/16, 3/8?
Fyi this is on a 41 9n
Thanks,
Derek G
Thanks,
Derek G
