No gas flow
Tony in SD
1948 8N front mount of course original 6 volt has no gas flow. I took the sediment bowl off, opened the gave valve wide open with2 of stale gas in the tank and it has no flow. Glass sediment bowl has a hard film on the inside of the bowl that is soaking overnight. My next step will be to remove the sediment/valve from the tank. I plan to clean all 3 filters. Any other suggestions?
If you took off the sediment bowl\screen and have no flow its either the valve not functioning or the screen in the tank is plugged. You likely need to remove the valve.
I've used compressed air to blow into the line to clear it out but be careful I've had sediment bowls also explode by doing that
