woodman1928
After restoring my lift cover with new main bushings new ram cylender and Modern oring piston i went to reassemble my draft conroll spring and i realized it was hitting the bolt heas and not sitting on its seat. Ehen i dissasembled it it had 1/8" thick flat washers under the bolts heads so when i resabled it i put those back i think those washers are why the spring is hitting the bolt head just trying to figure double check to make sure their isnt supposed to be washers under those bolts.
Thanks, Derek G-[/img:6baeb1d187]
