Possible 39N
Ishmeal
https://www.facebook.com/marketplace/item/1518350421928023/
Not sure if the copied link is useable. It's listed as a 1949 9N in West Virgina FB Marketplace.
dual ribbed fenders, snap in gas door, matching brake pedals, starter on the dash, 32 inch tires and one smooth hub- yep, its an early 9N!
Last year they had it listed for the higher price. They changed it in the title but not in description.
It shows many early 1939 9N features but he doesnt list the serial number. That would help sell if indeed an early 9N. I see double ribbed fenders; 32 Hat Rims; One
Smooth Hub, one riveted; Donaldson Air Cleaner; Snap-In Battery Cover; Screw-On Chromed Ball in shifter lever; Correct 9-hole non-flip seat; Start Pushbutton on LH Dash
panel; Key Switch On RH Dash panel; 1-Wite Starter Motor; but I cant tell if it has the small Generator and if an 9N-A GEN the correct VR with it; has the wrong steering
wheel- should be a 4-spoke; the wrong grille, should be the aluminum horizontal bar style; the wrong PTO cover; the running boards are not correct 9N/2N never had them;
and the front wheels/tires are 16 not original. Cant see: Voltage Regulator (if it as one); Gas Tank Fill Port; Ignition ON Lamp on dash; Light switch on LH dash
panel; and a few others. What is that linkage running at the lower bottom LH side?
TPD
