Loader hydraulic leaks
I have a 9N with a bucket loader and the hydraulic pistons on the loader leak badly. Can anyone identify the seals I need and where I could get them?
This post was edited by [email protected] on 08/09/2022 at 08:29 am.
Hard to say what seals it needs given the identity is not certain, and the bucket tilt cylinder is likely someone's add on, not factory equipment, if you do ID the loader. Pictures of the cylinders themselves might get you some good guesses. You will likely need to take the cylinders apart, pull the sealing parts, and have a hydraulic shop match them up. Or if you want to find them yourself, Baum Hydraulics is one place, that has online catalogs with drawings of individual sealing components you can go through to match your types with and measure for size. Then you can order the parts you have chosen from them. Depends how comfortable you are doing such and the risk of ending up with parts that don't fit.
Most of them loaders have oneway cyls, pressure up, gravity down. No piston seals just VEE packing on end where rod comes out with a wiper to keep dirt out of seal. Any good hyd shop will have or can get.
