logan.ambrose22
New User
Ive got a Massey Ferguson 180 multipower serial number
9AII573. Regardless of if Im in high/low range or high/low
multipower, whenever im moving up hill the tractor will slow and
come to a stop for up to 10 seconds before it starts moving
again. It just has no power when moving even up the slightest
slope. In the lower range/gears it will keep moving, but you can
tell its struggling. I replaced the multipower/transmission filter
(the one in front of the radiator), it did have some metal
shavings in it. I also replaced all the hydraulic fluid. The
multipower switch is engaging. I can feel it engage and slow
down or speed up. In high multipower, it engine breaks going
down hills. The auxiliary hydraulics seem to working, as well as
the three point. Is the hydraulic pump bad? Or could it be
something else? If I need to split it, thats fine, I just dont want
to split it if it could be something else. Thanks everyone in
advance!
advance!
