rim width
montidale
04-02-2022 10:40:20
A while back I posted about finding a rear rim for an N series tractor. I decided to get a loop style rim. The tires are 11.2 28's. I see there are different widths of rims available. What is the proper width rim for this tire size? Or is there a way to measure the rim width with the tire mounted in the rim?
montidale
04-03-2022 09:48:43
 Re: rim width in reply to montidale, 04-02-2022 10:40:20
Dean, I believe you are right. I measured the rim as per jimtrs and it measures just under 10 in. overall. Thank's all for the input.
Dean
04-03-2022 05:52:10
The correct 28 rim width for 9/2/8N tractors is 9 as properly measured according to jimtr's posting below. The overall width of the rim should be approximately 10.
If your N is an NAA (53-54) add 1.
Dean
Dean
04-03-2022 06:48:56
 Re: rim width in reply to Dean, 04-03-2022 05:52:10
For whatever reason, the website strips out the inches double quote marks.
Dean
jimtrs
04-02-2022 11:34:48
Wheel width is measured from inside bead to inside bead, down where the rubber sits. Most wheels can be measured with mounted tires. Just need to get a tape or scale from one side through to the other side. Can't do it on the old hat rims
Third Party Image
old
04-02-2022 11:10:36
Rule of thumb is the rim is 1 inch narrower then the tire so in your case the tire is 11.2 inches wide so the rim should be 10 inches wide
John in Mich
04-02-2022 17:19:20
 Re: rim width in reply to old, 04-02-2022 11:10:36
From M.E. Miller tire: 11.2-28_(10-28) I would get a 9 rim.
old
04-02-2022 19:20:59
 Re: rim width in reply to John in Mich, 04-02-2022 17:19:20
Either way it goes the best way to know the rim size one need is to simply read what is says on the side of the tire. I have not seen any rear tractor tire that doesn't say what size rim it should be mounted on
