Odd 8N Hydraulic valve
Greg NE
Location
Duncan, Nebraska
Anyone ever see a setup like this before on an 8N? First time for me.
(quoted from post at 18:50:10 01/22/22) Anyone ever see a setup like this before on an 8N? First time for me.
<img src=https://www.yesterdaystractors.com/cvphotos/cvphoto114874.jpg>
<img src=https://www.yesterdaystractors.com/cvphotos/cvphoto114878.jpg>
<img src=https://www.yesterdaystractors.com/cvphotos/cvphoto114879.jpg>
<img src=https://www.yesterdaystractors.com/cvphotos/cvphoto114880.jpg>
Its a check/lock valve designed to run a FEL off the test port. You use the 3pt lever to extend the SA cylinders on the loader and then move the 3pt lever back to the mid-point. The valve locks the cylinders at that point to hold the load. When you move the 3pt lever to the full down position it depresses the spring loaded stem which opens the check valve inside allowing the loader to lower.
TOH
Thanks for the information!! That explains
why it looks like it hasn't been used in a
long time. I'm 6 foot tall and I was
standing up straight when I took those
pictures. The tractor is on aftermarket
stilts for like a highboy sprayer setup and
was used for a tow line irrigation setup!
(quoted from post at 19:04:20 01/22/22)
TOH
ther connections? What does the flow schematic look like?
(quoted from post at 01:26:13 01/23/22)
TOH
Its been so long since I had one apart I don't remember the details of the porting. Many years ago I tried to replicate one - I'll see if I can find my experiment and refresh my memory.
TOH
TOH
Its a fairly common item so I decided to try and find the source. Turns out it was made by Ferguson for use with the L-UO-20 hydraulic manure loader. N tractor club has the loader manual wgich contains a page describing "theory of operation". Here is an image from that page showing the circuits.
TOH
(quoted from post at 19:33:44 01/22/22) Thanks for the information!! That explains
I would like to see a photo of the tractor
(quoted from post at 11:02:39 01/24/22)
e too, but while we wait, this one will get you up above the tomatoes.
(quoted from post at 09:12:34 01/24/22)
Farm ingenuity at it's finest
Sorry, I didn't take any of the whole tractor. If you search Kobza Auction in David
City Nebraska and look at their Auction Time page you can see more of it. It sells
on 1/26/22.
Link to the auction https://www.kobzaonlineauctions.com/auctions.htm?to=https%3a%2f%2fatauctions.kobzaonlineauctions.com%2flistings%2ffarm-equipment%2fauctions%2fonline%2f210838281%2f1950-ford-8n%3fdlr%3d1%26crmid%3d10135735%26domainid%3d14265%26sps%3d1%26if%3d1
Also a photo from the auction below. There is 32 more photos in the link above
This post was edited by KristofMI on 01/26/2022 at 05:52 am.
