I have a 41 9N that I wanted to see if anyone on the forum would be interested in before I try to sell else where. The previous owner told me it was a 41. The engine doesn't not have a stamp on the side, so at some point it was replaced.
Ok, the bad first. I got this tractor with several implements because it didn't run. The owner said it had lost compression. I brought the tractor home and checked for compression. It didn't have any compression. PO said it had been sitting for a while. So, I started to soak it with MM oil. It did turn over freely so I figured it was stuck rings. After many soaks through the spark plug hole, still no compression. I did pull it from one shed to the next and when I pulled it in gear, I started to get air out of the cylinders like it was starting to make some compression. I figured I would pull the head and see if I could see any major damage. Pulled the head and there were no major scratches or damage to the pistons or cylinder walls. I was thinking stuck vales. I put MM oil on the vales and turned it over and let it soak. After several soaks, all valves were move fine and I could put a little bit of oil around the head of the valve to see if they were seated. It didn't drain right through so I thought I would have a half way decent seat. Bought new head gasket, exhaust/intake gasket and valve cover gasket and buttoned everything back up. Still won't start. I checked spark and I think there is an issue with spark now.
The good. This tractor has good rubber front and back and good rims. Rims have been replaced with loop rims. Sheetmetal is in good shape. Some dents in the dog legs, but other wise the hood and fenders are in good shape. Better then my running 8N. The hydraulic pump does work because you can spin the PTO and the arms will raise. The PO had regularly tuned this tractor up at the local Ford dealership. I have all the receipts that go along with it. It has an extra carburetor. Both carbs are not originals. Two square coils, 5 distributor caps that look in good shape, a couple rotors, set of points, and I think 3 sets of plugs that also look usable. When pulling the tractor, I moved through the three forward gears and all was fine and the clutch engaged and disengage the way it should.
The bottom line is I just don't have time to mess with this tractor to get it running. I did some simple things to try, but have other projects that need to get done and I need to move this tractor on to someone who has the time to work on it.
If anyone is interested, let me know. I wanted to try here before just putting out there in other places.
I live between Baltimore and Frederick MD just to give you the location.
Rob
[/img:8612acbd86]
Rob
[/img:8612acbd86]
