(quoted from post at 03:32:56 12/23/21) HiYa Matt-
Front Mount or Side Mount distributor? Let's start here and at the end I will post several pictures that should help explain things clearly. FORD 4-CYL firing order on the N-SERIES front mount distributor is 1,2,4,3 CCW as viewed from the front, standing by the radiator and fan. Often, plug wires #3 and #4 get crossed up. So, can we assume you are attempting a 12V Switch out job? How did you test the 6V Coil? If you are using 12V with the front mount and the 6V Coil, do you have the Ballast Resistor in the circuit AND with the 6V Coil the additional, external, 1-OHM ceramic resistor in the circuit? If an early 8N/front mount did you replace the GEN with an ALT and also remove the Voltage Regulator from the circuit altogether? 99.98% of all non-starting issues are due to incorrect wiring regardless if 6V/POS GRN or 12V/NEG GRN. Do you have the ESSENTIAL MANUALS? The OEM Owner's Manual, the I&T FO-4 Manual, and the 39-53 MPC all have the wiring diagrams. JMOR wrote an excellent document on N-Series Wiring called WIRING PICTOGRAMS showing every correct way to wire these N's whether 6V or 12V. On the 8N with a 6V Coil and a 12V setup, you need the 1-OHM resistor in addition to the OEM Ballast Resistor. Swapping out to a 12V coil, you eliminate the extra resistor but still use the Ballast Resistor. On the angle mount, there's no Ballast Resistor but same applies for coils. If you have a front mount and you rebuilt it, did you install the unit correctly? Points and timing must be set and tested on your bench then unit mounted right on engine. Whether using a GEN or an ALT, you must use the belt tensioner device to maintain proper fan belt tension otherwise your system will never charge the battery. You should have copies of all of these for your 8N.
FORD N-SERIES TRACTOR w/FRONT MOUNT DISTRIBUTOR WIRING & FIRING ORDER:
<center><img src=https://i.imgur.com/xlChOv7l.jpg></center>
<center><img src=https://i.imgur.com/xu7sMo3l.jpg></center>
<center><img src=https://i.imgur.com/MXLPPwsl.jpg></center>
FRONT MOUNT 6V COIL BASIC STATIC TEST:
<center><img src= https://i.imgur.com/BCAtemml.jpg></center>
*NOTE - VOM MUST BE SET TO OHMS.
FORD N-SERIES TRACTOR w/FRONT MOUNT DISTRIBUTOR, OEM BALLAST RESISTOR:
<center><img src=https://i.imgur.com/Laahz4tl.jpg></center>
AFTERMARKET EXTERNAL 1-OHM CERAMIC RESISTOR REQUIRED WHEN USING A 6V COIL:
<center><img src=https://i.imgur.com/XRLi3vSl.jpg></center>
FORD 8N TRACTOR (after s/n 263843) ANGLE MOUNT DISTRIBUTOR:
<center><img src=https://i.imgur.com/t4l70hJl.jpg></center>
<center><img src=https://i.imgur.com/NWNKQAjl.jpg></center>
<center><img src=https://i.imgur.com/7KjkEJKl.jpg></center>
<center><img src=https://i.imgur.com/RagVHYul.gif></center>
FORD 8N w/ANGLE MOUNT DISTRIBUTOR & WIRING PICTOGRAMS:
<center><img src=https://i.imgur.com/TBC19a5l.jpg></center>
<center><img src=https://i.imgur.com/xQ2ojiTl.jpg></center>
FORD N-SERIES TRACTOR ESSENTIAL OWNER/OPERATOR/PARTS/SERVICE MANUALS:
<center><img src=https://i.imgur.com/2a28IGzl.jpg></center>
Tim Daley(MI)
