woodman1928
So il looking for some information that seems to be missing
This is for a 1941 9n. im trying to go as close to original as i can.
(DISCLAMER)
The only things that will not be 100 % stock is;
latter 6v generator with the bracket that goes on the head with the screw voltage adjustment... I hate belts getting slaky....
and iv added grease fittings to both ends of the brake actuator shafts after welding up the worn ends and Turing them down while still centered in the lathe i drilled thee the center 5" down both and then milled and cross drilled for a small flush fitting.... same at the clutch cross shaft that holds the throw out bearing fork as well as the clutch petal itself ......
so back to originality questions;
are the head stud nuts painted or not painted
if they are what about the nuts that hold the wire tube down or the accelerator rod.
is the accelerator rod and wire tube supposed to be grey or cadmium I think Cadmium
how about the accelerator rod bracket that bolts to the head?
how about the shifter grey up to the knob and then the knob is chromed?
also how about the bolts that bolt the oil filter and air oil bath on ( i think they would have been cadmium.
oil lines cadmium?
all oil fittings into block brass or cad steel?
any input will be helpful.
Thanks,
Derek G
(DISCLAMER)
oil lines cadmium?
Thanks,
Derek G
