This may be a dumb question.
I purchased a new 12V Starter Solenoid thru this website for my 8N. Its 3 posts. There is no indicator on the solenoid that I can see as to which of the
copper posts the battery should attach to. I installed it the same way the old solenoid was, with the small post the starter button wire attached to facing
inward (toward the engine). The battery cable is attached then to the right hand post, closest to the battery, and a bracket to the starter is on the left side
post.
When I try to start the tractor, the started 'clicks' once but nothing else happens. Do I have the solenoid installed incorrectly? Should I turn it around?
Is the new solenoid just bad?
I am baffled as to what try next.
Thanks for any advice!
Paul L.
Michigan
post.
Paul L.
Michigan
