Changing the front tires on my 1950 8N I found the hubs to be a little loose. Another opportunity to make things right.
Taking them apart I found these felt seals at the back of the spindles. <yellow arrow> They're about 1/2" thick.
The Master Parts Catalog does not mention them as a component of the front hub, or the spindle assembly.
Any clues which part this is?
Of note, the catalog does not list that thrust washer behind the seal. Is this a non-Ford solution?
