8N Steering Arm
Papillon
I've decided to overhaul my steering gear. It's the later version for an 8N. I have removed the steering wheel and the left steering arm, but I am struggling to remove the right arm. Lots of heat and penetrant oil - nope. Hitting with brass drift - nope. Two hammer technique - nope. I am frustrated. Any suggestions?
Thank you in advance.
(quoted from post at 19:27:39 09/14/21) I've decided to overhaul my steering gear. It's the later version for an 8N. I have removed the steering wheel and the left steering arm, but I am struggling to remove the right arm. Lots of heat and penetrant oil - nope. Hitting with brass drift - nope. Two hammer technique - nope. I am frustrated. Any suggestions?
"Two hammer technique"
You haven't whacked it hard enough using the "two hammer technique".
To get the arm off the box I use a Pittman arm puller... It may require some modifications... If they are tight that's a good thing if they are loose that's a bad thing... I have posted pix but can not locate them at this time...
Take tie rod loose at the lower end.
When the box is off, if you need the arm
off, lay it on an anvil or heavy support
and do a modified two hammer technique
with a sledge.
(quoted from post at 11:05:24 09/15/21) Take tie rod loose at the lower end.
with a sledge.
Extreme force always damages parts. So, nope to an anvil and sledge.
This got it off - Posi Lock 104 4" Reach, 0.5" - 5" Spread, 5 ton Capacity 3 Jaw Puller
(quoted from post at 01:56:43 09/17/21)
with a sledge.
Good deal beating it off was poor advice...
