Replaced with new gov. and new carb. I have the right pto speed at 6 notches from stop on the throttle, after that it over raps even with stop screw screwed clear in against stop. Can
not get full use of throttle to end of throttle plate. I looked at another 8N linkage and the gov. arm pulls way back on that one , also it extends the gov. spring. Mine does not. I have adjusted the throttle rod, makes no difference. Any other ideas from you N Ford guys? Thanks.
