My 8n came with anti-sway chains that go from the stabilizer pin under the trumpet end, to the ends of the 9-hole drawbar. On one end of the chain is a steel plate with a hole that slips over the
stabilizer pin. The other end of the chain is a bit longer than necessary, and just chain. How do I connect that to the drawbar? I'm guessing that there should be a steel plate that slips over the
end of the clevis on the drawbar, which has a slot milled into it to accept a link of the chain. What might this be called, and where do I find one? I tried using one of those bowling-pin shaped
links, but I snapped one this week skidding logs. Need something as strong as the chain.
