8N Crankshaft Pulley
Papillon
Any recommendations for removing crank pulley? Is it going to be a tough pull once the crank bolt is off? While I have the front axle off I want to install a speedi-sleeve on it.
(quoted from post at 13:03:07 09/08/21) Any recommendations for removing crank pulley? Is it going to be a tough pull once the crank bolt is off? While I have the front axle off I want to install a speedi-sleeve on it.
hy do you want to install a speedi-sleeve on it?
If its a original pulley they normally slide off. Original are not the rope wares a wide ware ring a speedi-sleeve is a waist of time they are so thin they ware thru fast. I am not a speedi-sleeve fan I have seen to many fail/ware thru : (
