Top Link Rocker
DonTheNewby
08-26-2021 18:47:48
Hello Gentlemen,
I have a 51 8n and needed to replace the Top Link Rocker. I originally had a 3 pin rocker.
I purchased an after-market one from our awesome host here.
The challenge is it won't fit on the tractor. Its too narrow by about an 1/8 of an inch.
Any suggestions???
Tim PloughNman Daley
08-29-2021 07:22:59
 Re: Top Link Rocker in reply to DonTheNewby, 08-26-2021 18:47:48
Do you mean the pin that connects onto the case is too small or that the hole spread on the implement linch pins is too small? You need part number NCA-535-A. The 3-Hole Rocker uses p/n 8N-486-B to connect the rocker to the case boss. It is 1 in diameter and 3-5/16 long. It matters where you buy from.
Tim Daley(MI)
R Geiger
08-26-2021 19:16:26
I would call them and see what they say!
