Confirm that you have voltage to the coil. Battery voltage, points open. About half that if the points are closed.
Battery voltage means 12.65 volts on a 12v system and 6.35 volts on a 6 volt system. A light will not tell you that. Get a meter. The number 1 cause of no spark
or a weak spark is a weak battery.
Do you have battery voltage across the points when they are open? (with the points open, put one probe on one side of the points & the other probe on the
opposite side of the points) Verify the gap on the points at .025. Then, dress the points by running a piece of card stock or brown paper bag through them. New
points sometimes have an anti-corrosive dielectric coating on them & old points can corrode or pick up grease from a dirty feeler gauge or excessive cam
lubricant. (I always spray my feeler gauge blade off w/ contact cleaner.) Make sure you have voltage across the points, as in past the insulator on the side of
the distributor. That is a very common failure point on sidemounts, along w/ the attached copper strip. It's hard to find a short there because it is usually
an intermittent . So 'wiggle' the insulator & the copper strip a bit when you are doing your checking. If you find the short there, the Master Parts catalog
lists everything you need on page 154. You can make the strip and you could also make the insulators as well. But, somethings are just easier & in the long run
cheaper to buy. Get the strip, 12209, screw 350032-S, 12233 bushing & 12234 insulator & just replace it all.
If you just replaced the rotor & lost spark, put the old one back in. Insure that the rotor fits firmly on the shaft & that the little clip is there. Make sure
the distributor cap is not cracked, doesnt have gouges in it from the rotor or brass shavings & doesn't have carbon tracks. Check continuity on the secondary
coil wire. Make sure it is firmly seated in both the cap & the coil. Next, remove the secondary coil wire from the center of the distributor cap, turn the key
on & crank the engine while holding the end of the wire 1/4 from a rust & paint free spot on the engine. You should see & hear a nice blue/white spark. If not,
you have a bad coil or condenser. Just put the old condenser back in to eliminate that as a possibility.
And do not buy a new part for the tractor until you can answer this question: how do I know the part on the tractor is defective?
75 Tips
