2 N 9N question
My friend not sure what he has. I looked it up and came up with 1946 2N . Serial number is 9N201826 and both brake pedals are on the same side. Please advise if
this is correct. Thanks in advance!! When did the brakes go to the same side?
(quoted from post at 14:28:18 08/24/21) My friend not sure what he has. I looked it up and came up with 1946 2N . Serial number is 9N201826 and both brake pedals are on the same side. Please advise if
ay have parts of more than one tractor. same side brakes-8N, 1947-48.
You are correct for the year and model from the S.N. At least that's what the engine originally was on. Does this tractor have a 3 or 4 speed transmission?
There was a kit available for the 9N and 2N to move the left brake to the right side to put both brakes on the right. We have a 42 2N with one of those kits on it. More information is needed to determine if the tractor is an 8N with 2N engine or not.
Mark
While no one thing alone definitively identifies it, I generally look at the wheels.... super easy to differentiate between 8n and 2n/9n
Since the owner does NOT know what the tractor is......Is it possible that he mistakes the two pedals on the LEFT side, to both be 'Brake pedals'???
Left side 9N/2N one brake...one clutch pedal!
Rt side one brake pedal.
Strange things DO happen!!???
GB
(quoted from post at 21:24:19 08/24/21)
Not quite right:
Left side inner pedal is clutch / left brake.
Left side outer pedal is left brake.
Right side is right brake.
So it is true that the two pedals on the left side are brake pedals.
This post was edited by HarryVanderpool on 08/24/2021 at 10:25 pm.
If you have both brake pedals on the right side then you probably have an 8N with a 2N engine. Lots of these N tractors have had engines replaced.
