I am having an issue with my new to me 8N. When I push the starter button the starter makes a noise like it is spinning but the engine wont turn over. If I push the starter button several times it may turn the engine over. If the engine turns a couple of turns it pops off and starts just fine. I have put a new starter and solenoid on. I checked the battery with a multi-meter and am getting 6.48 volts (running a 6V system). When I replaced the starter I looked at the ring gear and it looked fine. When the starter sounds like it is just spinning, I do not need to hand spin the engine to move the fly wheel so I dont believe it to be a ring gear issue. Where should I look next?
