OldTractorNoob
46 9N. Got the motor running. PTO spins. Put new fluid in the
transmission.
Running the tractor with the PTO engaged lifts the 3PT hitch
no matter what the control is set to. Lift drops when pump isnt
running.
Now I think I know that means the cylinders are leaking since
it drops as soon as I turn it off, but it would be nice to have
someone tell me for sure.
I cant seem to tell for sure what the problem is that I dont
have control. I took the side covers off and sucked a bunch of
fluid back out. There are two arms that come down, one on
each side, that move when I move the lift control. They seem
to go down to a rod between them. The rod has an irregular
spot in the middle, but doesnt seem connected to anything
else. Im assuming thats the issue.
What should that bar attach to?
transmission.
running.
