popgun48 lists tractor parts as remanufactured to spec. Well, I received a carb with worn throttle and choke shafts with old worn seals, a cracked venturi, a bent float, a worn float valve, a damaged idle screw. At that point I stopped looking. The only new part was the main gasket and a manifold gasket. The exterior had been burnished and all screw heads polished. Screw threads were still rusty. The price was expensive because it was "remanufactured and tested on a tractor. Ready to bolt on and go".
I have requested a full refund including shipping and taxes. I will let you know what happens.
This post was edited by Papillon on 08/02/2021 at 02:57 pm.
