CKain(MI)
On a 9N, where can I find instructions how to set the brake linkage, from pedals to drum. The dual rod, and the individual rod.
Thanks....
CKain(MI,A 9N has No dual or single brake rods? Just a single shaft on each side the petal is attached to.To adjust brakes there is a square adjustment widget on each side.Use a 12"crescent wrench first turning back and forth to free it up then adjust it with the wheel jacked up,till you can just feel some drag and the petal is at the top of its travel.
