Valve guide seals or valve stem seals
L.B,
52 8N is there a real difference or just a mixed nomenclature Ford tractor models 8N, 9N, 2N. Upper Gasket
Set with Metal Head Gasket. Set includes: cylinder head gasket, (2) valve cover side plate gaskets, (8)
valve guide seals, (2) manifold gaskets, (1) governor gasket. Replaces: 8BA6571, 9N6022, 9N9448, 7HA6521,
8N6051A.
Part No: VG8NM I bought this from our host for my winter project,but my winter came early in July. I am only replacing the intake seals.
Edit....
Guide seals are orings between guide and head... I don't think n's used stem seals.
This post was edited by Smokeonthewater on 08/04/2021 at 09:24 pm.
You are going to have come up with some kind of tool to pull guides down to remove keepers. Then remove as assembly or take keepers retainers springs then pull valve then remove guide then reassemble the same way.
(quoted from post at 16:40:16 08/04/21) 52 8N is there a real difference or just a mixed nomenclature Ford tractor models 8N, 9N, 2N. Upper Gasket
8N6051A.
"I am only replacing the intake seals."
It would be interesting to know "the rest of the story"/what has convinced you to set off on this quest?
