Ford 8n Valve Woes
Funford
New User
Need some help--I dropped the Lash cap from the #1 exhaust valve down the oil drain hole directly between the #1 exhaust and intake valve--the engine is still in the
tractor--does anyone know if the cap would fall around the cam shaft and into the crank case? I haven't tried to fish it out yet or rotated the engine.
Any advice would be appreciated--thank
I most lickly went all the way to pan but there is couple baffles cast in pan will not let you fish out. Find new free turn cap and go on. It may work around and come out with oil change some day
THanks for the reply--as I have never been past where I am now with the engine appreciate the feedback
